Oil Leak Dye Detection Test: Is it worth the cost?
+1 to Tester’s comments.
Besides, a bit of oil weepage if the car is high mileage is normal and harmless, as long as the level is kep above FILL and you’re not getting spots on the garage floor. If you’re leaking an excessive amount, or your garage floor is getting spotted, post back.
Otherwise, ignore them. Yours would not be the first car brought in for an oil change wherein the dealer “finds” $3000 worth of work that “needs” to be done. 99% of the time the “oil leaking” problem is bogus, unless of course your level truely keeps dropping.
