Using the dye to locate an oil leak is a last resort. Your mechnic is right. You first wash the engine and then try to locate the oil leak. The only time the dye is used is if it’s very difficult to locate the leak. And it shouldn’t cost $120.00. More like $20.00. And that’s only because the dye isn’t cheap.
