When did that modern truck have a wood bed???
My midsize truck has a very slick bed floor, what ever you put back there, unless tied/strapped down, will just slide around, so I put a bed mat back there and no more sliding around…
What is the difference in buying a nice car vs buying a nice truck when the cost is about the same, other than the truck can be used as a truck if needed, whereas a car is very limited compared to even a 5’ truck bed…
I can park under a tree and climb in the bed and walk around while trimming low hanging branches, much safer than standing on a ladder and plus you would have to keep moving the ladder to cover as much space as the truck bed would give you before having to move the truck, so the truck is more efficient and safer…
I can also load the bed down to move things that would not fit in a car, or could damage the car…
If I need something bigger, I can rent a trailer or use my full size truck…
You do realize that Chevy still offers the WT trim, Ford offers the XL trim, and Ram offers the Tradesman trim levels for base model work trucks, they are still required to have standard safety equipment and features such as back up cameras <10,000 GVWR, so they (mostly) have infotainment centers now…
My little 2wd Pavement Princess…
Ohh yeah, and this is what I mostly haul in it… I have the rear seats folded down with a heavy moving blanket down for plenty of room for my fur babbies, but I can remove the blanket and unfold the seats in a minute or 2 and carry 5 passengers in it and still have room to haul things around…
So sure, I could have bought a Camry instead of the truck, but I wanted a truck more, and I can use it like a car, but also as a truck when needed…
Oh BTW, with my bad back, it is much easier to unload groceries than having to bend over to remove them from a low trunk floor and I don’t have to worry about hitting my head on the deck… Plus it is easier to get in and out of…
