I have a 1992 Mazda 929 in which the heat does not work while the a/c does work perfectly. When the problem first occurred the fusible link for the A/C was broken (indicative of some electrical overload). I replace the fusible link and still no heat.
I went under the passenger side of the dash and changed every visible black box (fuse/sensors)that is attached to the heater core unit. After that the heat still did not work.
In relation to this problem the care now runs hot whenever I am a red light or in stop and go traffic.
This seems to me a that a mechanical gate from the engine is not opening to allow the hot fluid from the engine to get into the heater core.
I have searched all resources to get a sense of what valve/gate is not opening.
Please help, it is winter time and I need the heat in this car really, really bad.
