This is the time of the year we hear reports of “does not crank” which I assume is your problem too. It happens now b/c the temperature is getting cooler, and that adversely affects just about everything to do with the cranking operation. Here’s what I’d do in that situation
Batteries don’t last much beyond the three year mark in hot climates like Houston, so if yours is near to or over the 3 year mark, makes sense just to replace the battery. At that time the connectors and posts will be cleaned and tightened properly, so at least you’ll know you have a good battery for the winter, and it may indeed fix the problem completely.
If not, you may have a failing starter motor. Ask your shop to check for that. If you’re a diy’er there’s some voltage tests you can run yourself if you like.
