A while back I posted about some serious clunking sounds.
http://www…ot-klunky/
My Tundra Got Klunky - TundraTalk.net - Toyota Tundra Discussion Forum
It seems that maybe the problem is cured. Solved. Removed.
I’ll copy, as accurately as possible, the invoice from Concord Toyota.
CUSTOMER STATES VEHICLE CLUNKS WHEN ENTERING DRIVEWAYS, ETC—CHECK & ADVISE
CAUSE: DEFECTIVE TRANS MOUNT/CROSSMEMBER
TC9005 R &R TRANSMISSION MOUNT AND FRAME CROSSMEMBER—NO. 3
8071 WT
5347 WT
1 12371-0F080 INSULATOR, ENGINE MO
4 90119-08895 BOLT, W/WASHER
1 51203-0C030 CROSSMEMBER SUB-ASSY
PARTS: 0.00, LABOR: 0.00, OTHER 0.00
53842 DEFECTIVE TRANS MOUNT/CROSSMEMBER TC9005 T1-91 T2-14 1.5 TEST DROVE AND HEARD NOISE RECOMMEND REPAIR PER TSB TC001-06 AND RECHECK, PERF TSB REPL MAOUNT AND CROSSMSMBER
So , the moral of the story seems to be:
If your truck is a clunker, take it to the dealer. They may fix it.
Thank you very much for the post. Not only will I file the fact that there exists a TSB for this particular problem, but it’s also great to hear a story of good and proper support from the dealer.
Happy motoring.
