Okay, I have a stumble when accelerating (even gently). I get a trouble code of “misfire on cyl 4”. I’ve replaced the plugs twice, the coil pack twice, the MAF sensor, the wires twice, I’ve swapped the wires between 4 & 3, the injectors between 4 & 3. Problem does not follow wire, plug or injector. Compression is good. I understand that there are only two coils that fire a pair of cylinders. Not sure which cylinder is shared with #4 but all other cylinders are strong performers. I’m stumped. Help!!
Related topics
| 98' Corolla Cylinder 4 Misfire | 2 | 747 | March 22, 2010 | |
| P0304 - Cylinder 4 Misfire | 7 | 2154 | April 10, 2013 | |
| Misfire problems | 9 | 2360 | February 25, 2017 | |
| Cylinder misfire after replacing coil | 4 | 6025 | April 29, 2017 | |
| Cylinders 1 & 4 misfire | 8 | 17788 | December 14, 2009 |
