Been a long day. Im not good at putting pictures on here. So ill try again. This is on my 89 year old moms ford explorer.its a 2012 she bought new. 3.5 engine. All work has been done at the local Ford dealer. 75k miles. I looked it over and decided to check the air filters and a few other things. I noticed the coolant looks pink, it should be orange. She has ever receipt from the dealer service. Its never had any work done involving coolant. Just tire rotation and oil changes. Sad to say she’s never even had them change the air filters. So im wondering why does the coolant look pink?
If its a blend of pink and orange, there’s no telling how long its been this way. Her last service was in March of 25. Im wondering if someone topped of the original orange with pink. Maybe at the dealer. The only other people who would ever lift the hood would be my nephew or brother in law. Both said they haven’t touched it. I guess its time to schedule a flush to be safe.
The coolant was scheduled to be replaced after 6 years, then every 3 years. The dye used to color the coolant will fade after 14.5 years.
Interesting thought…I hadn’t considered that. It apparently hasn’t had a weird chemical reaction. My grandpa once added the old style green coolant with dexcool because he just didn’t know better. It more or less turned to sludge
I d have it drained, flushed, and filled with the factory spec coolant.
Ford sats the original coolant is good for 10 years or 125000 miles so just have it changed/
Also here…
Hard to tell, but I don’t see any cloudiness in the coolant, it looks pretty clear. For this reason, I would NOT flush the system, just drain and refill with the correct coolant, premix 50/50 or mix your own with the correct concentrate and distilled or purified water. If you use purified, make sure it is not purified drinking water as after the purification, they add minerals back in.
This will refresh the the system with enough new corrosion inhibitors to last at least another 5 years/50k miles. See the owners manual for the second and subsequent coolant change schedule. It is typically shorter than the first change.
Doing a flush has a chance of introducing contaminants to the system. If you do opt for a flush, it would be best to do it at the dealer where their flush (coolant exchange) machines typically only do Fords so are less likely to have had non Ford spec coolant in them. Since you coolant color is not what you suspect, someone may have added the wrong coolant to top it off at some time and than might be reason enough to justify the flush.
How is that possible?
Ford has used many different coolant over the years, so any coolant flush machine at a Ford dealer will probably have been used with old school Ford green, Ford gold, Ford orange, etc.
That depends on the integrity of the shop owner or mechanic that owns the machine.
Again, one reason I prefer to not flush.
Anything left in a flush machine (coolant or trans) is 1st sent out of the machine and just like the fluid in the vehicle is flushed out of the system… The remaining fluid left in the machine is the 1st fluid to leave the machine and therefore the 1st to get flushed out followed by new fluid and as Tester mentioned, the extra makes sure no wrong or old coolant is in the vehicle… As long as it is done correctly…
