My Mazda sounds like a bird chirping. It gets louder when I give it gas. I had a new belt put on it and it still hasn’t stopped
The sound you are hearing may be due to a bad bearing in the idler pulley for the fan belt. If the pulley wobbles around it is bad.
Thanks for the reply, but the belt doesn’t wobble, after it’s been removed and cleaned, plus like I said it’s less than a month old(the belt) it still makes noise.
