Low coolant warning and hot engine
So the engine block, the water pump, thermostat, and pcm have been replaced. Works fine except: at high speed engine temperature is good. At low speed or idle it heats up rapidly to just above half-way and stabilizes. Then the low coolant warning like starts to flash and comes on permanently. Driving at high speed reverses the process. The radiator fans are working, and the coolant is in the radiator - it gets hot to touch.
Is the radiator full and all the air out? That’s the question. You need to make sure the radiator is actually full with no air pockets. Hot to the touch is not the way to check for coolant.
This definitely sounds like air in the coolant system. If you have the 3.8L, which most Intrigues had, there is a bleeder valve on top of the thermostat housing. You need to open that valve (engine completely cool, of course) before filling the engine with coolant. When coolant starts to come out of the bleeder, let it flow for a few seconds, then close it off, tighten, and finish topping off the coolant. Hopefully, no damage was done by operating the vehicle this way and your problems will be solved.
My resevoirs seal around the middle of he two molded halves is leaking… my engine is running very hot I can tell and I’m going through collolant n water like crazy… would this break in the seal cause temp problems?bit like is boiling right away and puts off some serious heat… I also hear popping when I first fill it up very high…band was wondering what caused this? My water pump was just replaced by a shop
@mcorron19_169196 Please stop tagging on to old threads . You will get much better answers by clicking on the ( New Topics ) button and starting your own thread . It is doubtful that the people from these 10 year old thread will reply.
