July 2023 Daily-Driver Cold Tire Pressure Survey Revised Release
July 2023 Daily Driver Cold Tire Pressure Survey - What do you normally run?
  • A) 2-5PSI below Vehicle Placard Specified Cold Tire Pressure
  • B) Within Plus/Minus 1PSI of Vehicle Placard Pressure
  • C) 2-5PSI above Vehicle Placard Pressure
  • D) 6-10PSI above
  • E) At, or close, to Maximum Cold Pressure listed on Tire Sidewall itself
  • F) Other: Different Front and Rear pressures NOT specified by Vehicle Mfg.
0 voters
G) 2-5PSI above Vehicle Placard Pressure and let it drop to 2-5PSI below Vehicle Placard Specified Cold Tire Pressure before adding air again… lol
and on one vehicle F) more in front for less rolling resistance and less in the rear for added traction from a dig or roll…
About 10.5 in the rear :wink: :rofl:
Ok. Now please select the radio button option closest to what you do.
ā€œI can’t drive 55ā€ :wink: :crazy_face:
I did say ā€˜daily driver’, but ok, lol!
Sorry, I was just in one of those moods, :wink:
I voted before my 1st post… but I have also daily drove my hot rod many times… just not safe to drive in the rain, in a curve, after installing the spool… lol
Any other takers? So far, within 1psi of vehicle placard is in the lead.
