I’ve a 1998 Jeep Cherokee SE 4.0
In the morning when it’s cold the motor sounds like it’s in high rev but the jeep isn’t really moving all that fast - just more noise than speed. After it warms up it has plenty of pep and can leave rubber.
No rpm - it’s the basic model - cassette player and roll up windows
Engine sounds like a higher rpm without the pep - Until it get’s warmed up.
No air pump that I know of
No fan clutch
If the engine sounds like it’s revving but the car isn’t “going,” it sounds like the transmission is slipping. When is the last time you had the transmission serviced (fluid & filter)? Have you checked the transmission fluid level?
I got that part but I’m saying it didn’t act Sluggish as far as taking off when I stepped on the gas. Now it just doesn’t want to move until it warms up. Is there something that affects the torque?
While I am no trans rebuilding expert, it sounds like you have hardened seals. When the trans warms up, the seals become more compliant, and all seems okay. Until the next morning.
