anyone had problems with vehicle running for several weeks to month then not starting. It will crank then die. It will do this 4x then when you turn the key, nothing happens. If the vehicle sits for a day or so, it will start back up. It has had a new battery, battery cables, anti-theft switch, starter, ignition switch, computer module, and still does it every once in a while. The vehicle is a 1998 Dodge Caravan. Thanks
Related topics
| 98 Dodge caravan (intermittenly starting) | 8 | 789 | October 11, 2010 | |
| Stalls after starting | 0 | 386 | September 3, 2009 | |
| Intermittent starting problem | 1 | 450 | July 24, 2008 | |
| Start -- cut out --unable to hold start | 3 | 640 | June 13, 2010 | |
| Continued starting problem | 3 | 611 | October 11, 2010 |
