Intake Manifold Leaks>>>WHY?
TwinTurbo is correct about time being a factor. Through luck of the draw some cars make it their entire lives without an issue and some do not.
Rubber anywhere degrades over time; be it engine gaskets, tires, accessory belts, master cylinders, brake lines, A/C seals, you name it.
