If I don't use AC, will there be no AC maintenance?
When I grew up, AC was very uncommon, and I remember sweltering through many 100+ deg days sweating my rear off in my dad’s car. When I finally bought my first car with AC, I said to myself I’d never buy another daily driver without it, and I never have. I LOVE AC. Dry heat my hind end. Your oven has dry heat. Set it at 100 deg, and stick your head in there for an hour and tell me how you like it.
People who refuse to use their AC think it’ll be fine, but along with the refridgerant, there’s also lubricant for the compressor bearings and seals. Don’t use it, the seals will dry up and fail.
Remove the system from a car and sell the pieces off? Really? Seriously? Are you guys really that cheap? The modern AC is so integrated into the car’s climate control system, the rest of the system probably wouldn’t work because the computer will sit there wondering where the heck the AC components are.
About 20 years ago, my sister-in-law’s husband, a notorious cheapskate, bought a car without AC. Dealer tried to talk him out of it, but he stuck to his guns. Then, about 6 years later, he decided to sell the car. The prospective buyers would show up and upon finding out there was no AC, all immediately said “sorry, not interested” and walked away. He eventually did sell it for quite a bit less than he wanted simply because no one was interested in a car without it. And that was in Minnesota!! He later admitted to me it was a mistake he would never repeat.
:triumph:
No you don’t need to maintain it and I agree with George SanJose who suggests removing and selling the compressor and evaporator for a few extra bucks. These could be sold on EBay or Craigslist as suggestions. There is scant reason for using the air conditioner for defrosting in the winter except as an excuse by designers to run the compressor to help preserve the rotary shaft seal. If you will keep the car to scrapyard value and live as you say where air conditioning is infrequently needed as I do, have at it! My wife would not agree to do it but I would be happy to save new car money for an air conditioner deletion option.
Removing it would be nuts, in my opinion.
Next to no benefit.
Huge cost - try and sell a non-ac car that’s been butchered.
Everybody wanted air conditioning because the manufacturers removed flow through ventilation and vent windows. The last car I owned with actual ventilation was an 81 Horizon and it was quite comfortable without a/c. I then got an 87 Reliant w/o a/c and it was unbearable in the summer because it had no cowl vents.
Actually, using the air conditioner in the system for windshield defrosting has real benefits. It isn’t just an excuse by the designers to keep the seals healthy.
Fog develops on the glass when warmer moisture-laden air comes up against the colder glass and the barrier layer temperature drops, reducing the amount of moisture the air can carry, and the moisture gets deposited on the glass as condensation. Remember that cooler air has less moisture carrying capability than warmer air; hence “relative humidity”. “Relative humidity” is a “rating” of the humidity being carried by air relative to its capacity. 60% RH in 40F air is a lot less moisture than 60% RH in 80F air.
Removing moisture from the air coming through the defroster vents very much improves the function of the defroster by moving warmer air with low RH against the glass, which will tend to absorb the fog on the glass, removing the fog and/or frost. Moving moist warm air against the glass can actually increase the fog. Like fogging a mirror by breathing on it. Hence, the AC is pu in series in the system to remove the moisture from the defroster air. Keeping the seals healthy is only a secondary benefit.
As regards removing the components and trying to sell them for parts, I think it’s foolhearty. I cannot imagine anybody paying any worthwhile amount for used parts of unknown history. And you’ll never get anywhere near the price necessary to offset the amount it’ll devalue your car.
The engine would, however, not care as long as you redid the belt(s) properly to compensate for he missing compressor. The choice is yours.
Some cars after the 87 Reliant had it still. My early 90’s Corolla has excellent fresh air ventilation.
Back in the late 1960s, my dad and my brother both owned 1963 Buick LeSabres. My dad’s Buick had almost all the options. It also had a Mitchell Mark IV add-on air conditioner. These were heavy units with a box under the dash that contained the evaporator coil and the blower. The compressor was, of course, under the hood driven by a belt. I am sure that the facory air was,more efficient, although the Mark IV cooled.the car well, My brother’s 1963 LeSabre had no power steering or brakes and even bad a 3 on the column manual transmission which was quite rare on a Buick. On a 375 mile trip where my dad and mother followed my brother and his wife with the cars similarly loaded, my dad’s Buick with the air conditioning on averaged 19.7 mpg. My brother with his strippo Buick averaged 19.2. Now I am sure my brother had the windows open which probably added to the drag. However, the Dynaflow automatic transmission on my dad’s Buick wasn’t the most efficient automatic. Both Buicks were well maintained and in good tune. I know which vehicle I would prefer for the trip. Now I am certain today’s factory air conditioning is much more efficient than the old Mark IV add-on unit. I really don’t think removing the air conditioning will have a noticeable effect on the.gas,mileage and not using the air on the highway will reduce the mileage if the windows are opened.
You still have to turn on the A/C from time time. I tried not using it and when I turned it on, it emitted a foul smell.
Even if the AC isn’t being used often, it’s still a good idea to run it occasionally. The refrigerant circulates oil that keeps seals and gaskets from drying out, neglecting this can lead to leaks and poor performance later on. Most modern vehicles automatically engage the compressor when using defrost or climate-control settings, so the system is already working behind the scenes more than many drivers realize.
A few minutes of operation every couple of weeks keeps everything lubricated and prevents odor or moisture buildup in the ducts. For anyone interested in learning more about maintaining vehicle cooling systems properly, you can visit here:socool.sg to explore expert advice and professional maintenance solutions from SoCool. Their insights on AC care can help extend system life, even if it’s rarely used.
I advise everyone to be VERY cautious about clicking on a link to a company that is located in Singapore.
I flagged it because of the link. Please remove it.
Oh this is old.
I can’t verify it but I was told back in the 70s the state of minnesota got ramblersbon low bids for their fleet. The came with air conditioning which was not allowed and somehow disconnected them. So a nice lady in her new dress heading to a meeting in 95/degee heat and sweating like a pig. Nice going guys. Comes a time to join the adults.
People who believe that “fresh air ventilation” is all that someone needs must live in areas that lack high humidity. My recently-deceased friend would visit me in the summer, after a 1 hour+ drive without turning on his a/c.
His clothing was always totally saturated with sweat, and his face was so red that I feared it would explode. But, he probably saved all of about 75 cents in the process.
:thinking:
Did you reconnect the A/C for her?
In the 1980’s, local cab drivers were not permitted to use the air conditioning unless there was a fare in the vehicle. While waiting at cab stands, the drivers would wait outside of the vehicles. The policy reduced fuel consumption, pollution and wear on components. The cab drivers were adults.
This was probably in the days of A6 and York AC compressors, which sometimes had a great effect on engine power, fuel efficiency, etc
I have no personal knowledge of any of it 40 years ago just what I was told by someone.
Yeah but the A/C sure worked great with those!
I remember them well
They were so heavy, you had to be careful installing them, lest you sprain your wrists
The refrigerant charge was always massive, often well over 3lbs for a car
But they blew ice cubes :ice: in your face :cold_face:
This is one of the most misunderstood concepts in automotive tech/repair.
I’ve had even ASE certified mechanics themselves, let alone shady tree mechanics and the general public debate me on the points you brought up, insisting that no, only the air conditioning mode uses the compressor/refrigerant.
You really can’t fix s t u p i d …
