IAC Valve Symptoms
Last year, I replaced my Idle Air Control valve because of stalling while idling. Could a defective IAC valve also cause excessively fast idle? Or, do I have to look elsewhere for the problem?
It could, but I would start by looking for vacuum leaks.
Try rapping on the IAC valve with the handle of a screwdriver while the engine is idling.
If the idle speed changes, the IAC valve is faulty.
