I rented out a 2022 C8 Z51
Have a friend who used to run that in a V-8 powered Porsche 914 named “Howard”.
You are quite correct. High speed runs are not for rookies. Even one misplaced rock that you hit at 140 mph can send you to Valhalla.
FoDaddy,
You made good and valid points for the C3,C4, C7 models you mentioned as supercars. Good job!!!
davesmopar,
That was an excellent reply where you mentioned about thinking 10 moves ahead and looking for signs of other car activity of possibly pulling out. Your reply was almost exactly how I was thinking. Also, I forgot to mention, a little bit before I approached the curve where I cut loose, I shut off the radio, I wanted full concentration not only visually, but through sound as well. If I know I am going to go fast, the radio is NEVER on.
So you are looking for more than just reliable and comfortable transportation?
You’se guys in Chicago.
