A Lexus still running pretty good at 218K, provided the oil burn rate isn’t more than one quart in 750 miles , I’d guess the engine should be good to 250K if the routine maintenance schedule is maintained. The transmission is probably the bigger big-repair-cost risk, assuming this is an automatic. If this car uses the viscous coupling method for the AWD function, that could also be the eventual show stopper. But like I say above, if the routine maintenance on all that stuff is kept up to date, conservative driving style, good chance you’ll get the full 250K.
Your increased oil consumption might be something simple too, like a leaky valve cover. Very common source of small oil leaks that don’t result in much oil dripping on the ground.
