Mountainbike,
With all due respect:
The air bag analogy doesn’t work here. With the air bag, the thing being pushed up is on top of the bag. With a tire, the thing being pushed up is in the middle completely surrounded by pressurized air. No matter how you slice it, this pressurized air is acting in all directions and is completely taken out of the equation.
I suspect that many folks think the air pressure is acting on the rim - just like the bottle jack acts on the cylinder. So let’s do a reality check:
My van using 15 X 7" rims and the tires are inflated to 35 psi. So if the air pressure is acting on the rim, it is pushing against a 15" by 7" platform at 35 pounds per square inch - or with a force of 3,675 pounds - and that would be 7,350 pounds per axle. Opps, way too much!!.
Don’t forget that the pressure is there whether the tire is loaded or unloaded.
Also, try a couple of thought experiments:
What would happen if I use a larger diameter rim at the same pressure? How about a smaller diameter rim? What about a rim so small in diameter you can almost take it out of the equation - like one inch.
How do bicycle rims work? If you take off the tire and only have the rim and the spokes - clearly the spokes on the bottom would buckle under the weight if the weight wasn’t suspended from the top of the rim. So in theory, the only spoke that matters is the top most spoke and the axle is suspended from it.
But seriously, in the big scheme of things, the actual working mechanism here is only of value to tire engineers and rim engineers. I’m sure they have figured it out.
For everyone else, it is just an academic game.
