Honda Civic EX
QUESTION again - I’m looking at this car for my son as his first car.
I had posted previously about another Honda to ask about repairs and any guidance.
Same goes here :slight_smile: we are looking for safe, reliable, and based on the Carfax is there anything Major i.e. belts or transmission for example that I’d have to be aware of before purchasing?
My initial thought was the vehicle was ‘maintained’ and maybe that is all it requires but I thought I’d see something else than just inspection/tires etc. so was concerned that maybe something routine wasn’t completed?
Thanks again - great responses in this group for sure!
2007 HONDA CIVIC EX
SEDAN 4 DR
1.8L I4 F SOHC 16V
GASOLINE
FRONT WHEEL DRIVE
Owner 2
Purchased: 2009
12/30/2009
33,386
  • Title issued or updated
  • Registration issued or renewed
  • Title or registration issued
  • New owner reported
  • Passed safety inspection
02/26/2010
34,083
  • Passed emissions inspection
02/26/2010
03/20/2010
34,255
  • Odometer reading reported
03/22/2010
03/07/2011
42,348
02/20/2012
52,224
07/28/2012
57,012
  • Vehicle serviced
  • Oil and filter changed
01/11/2013
62,543
  • Vehicle serviced
  • Tire(s) replaced
  • Tire valve stem(s)/core(s) replaced
  • Tire condition and pressure checked
  • Alignment performed
  • Wiper(s) replaced
07/18/2013
68,075
  • Vehicle serviced
  • Electrical system checked
09/23/2015
78,768
  • Vehicle serviced
  • Battery/charging system checked
10/07/2015
  • Vehicle serviced
  • Maintenance inspection completed
01/30/2016
79,117
  • Vehicle serviced
  • Tire repaired
02/19/2016
79,129
  • Vehicle serviced
  • Safety inspection performed
08/25/2017
82,865
  • Vehicle serviced
02/07/2018
84,451
  • Vehicle serviced
  • Emissions inspection performed
10/28/2019
92,197
  • Vehicle serviced
  • Tire(s) balanced
  • Tire(s) mounted
Throw of the dice
I don’t see where the timing belt was replaced based on time.
From what I found, all Civics 2006 and up have a timing chain and not a belt.
The car has a bit less than average mileage for an '09 and has been serviced more or less regularly.
As advised before… have YOUR mechanic check the car out before you sign anything. Have the engine carefully inspected to make sure oil changes were done regularly… the CarFax lists 2 times in 92K miles. Not to say it wasn’t done more often and not reported to CarFax… but have it checked.
Looks to me like the oil was only changed every 20,000 miles or so.
That would give me pause.
