High Mileage 70k+ Infiniti G35 '06 Fuel Injector Cleaner - Will It Help?
Short of an instantaneous clog of one or more injectors (which would cause a misfire and most likely trip the Check Engine light), a fuel injector problem is not causing a sudden, vast drop in fuel economy. Injector cleaner won’t hurt, but it won’t solve the issue. But you need to start by calculating your actual fuel economy as stated above. This could even be a case of a problem with the fuel gauge or sending unit.
