2003 chev. cavalier, 2.2, auto., Idle is normal without a/c (800 rpms) Turn on a/c, idle goes up to 1200 rpms briefly. After it is warmed up and a/c is turned on the rpms go up to 2,500-3,000 rpms. If the a/c is turned off, the rpms will go down to 1,500-2,000 rpms. Rpms will not return to normal until a/c is on and engine is off and restarted. My OBD2 code reader read P0507 idle system-rpms higher than expected and another mechanics scanner read idle air control valve. Several other people told me to replace the iac valve. I cancelled the computer codes and installed a new idle air control valve. That didn’t fix the problem. Help?
Related topics
| High idle | 0 | 270 | September 2, 2008 | |
| High idle | 0 | 253 | September 2, 2008 | |
| Cavalier Having A/C and Engine Problems | 7 | 7119 | August 25, 2014 | |
| Hard Idle When the AC is Off | 3 | 880 | June 13, 2015 | |
| Rev happy 300M | 7 | 1098 | September 18, 2012 |
