Heater core
my del sol started leaking water outta the heater core hose that leads 2 the bottom of the car and drips on the ground i smelt the liquid and its not antifreeze just water but its comin from heater core what could it be ?
That sounds like it is condensation drain. Likely it is located on the passenger side of the car right in front of the area they put their feet. It may smell a little musty. It is normal. If you turn off the air conditioning it will stop, but then you will be hot.
Aren’t you glad that sometimes these things are easy.
lol thanks thats what i thought it was just worried that it was the heater core dont wanna fix its a big pain
