So with the extra measure of cold this winter I was again freezing my butt.
Last year I tried all kinds of possible solutions non of which effectively worked and then it got Springy again and it became a minor issue.
This year, once again I was too busy to be without my service van due to workload.
Anyhow I finally bit the bullet and scheduled a day in the shop to get the heater core replaced. I requested the old core be left in the van so I could perform an autopsy with my saws-all.
After cutting the core into a few segments I observed what looked like a warm beeswax substance. Needless to say it insulated the flow of antifreeze from transference of heat to the air mass passing the fins but not enough to make a decreased flow of fluid even after a number of prior flushings.
My questions are as follows:
What causes this “beeswax” to form??
What could or should have been used to clean it out??
Is the same stuff in the radiator that will cause replacement to it??
If the same is in the radiator will it migrate to the heater core starting all over again??
Should I consider replacing the radiator or what is the best way to clean it to remove the junk??
I know that is a load of questions. If whomever would like to contribute an answer or comment, take your choice of question(s).
Oh, forgot to mention. My butt does not freeze anymore.
I was told that it was. However, I do have a concern based upon your first comment.
I never added coolant to the system it was always my shop. Just trying to understand
why this happened in the first place. Will be difficult trying to figure it out with all the time that has passed. Really trying to understand.
