Greetings Folks. 97 Town Car started making noise under the right side dashboard like someone is kicking and the temp is erratic. Sounds like a solenoid to a vent door or some such. Is this an easy fix or should I send it out? And, any other opinions? Great car otherwise. Thanks Much, Dworkin
Close, the blend door is probably broken hanging up the stepper motor. I am not too familiar with it, but folks at www.crownvic.net will be able to help you. IIRC, you may be able to check it out by removing the glove box and feeling it our or maybe see it with a flashlight and mirror.
