Heat inside car
92 Buick Reagal. I just don’t get enough heat in the cabin from the vents. It is -2c up hear in Toronto.
The coolant in the resourvou is full/hot.
Any advice will be greatly appreciated. Thanks. Brrrrrrrrrr! John
The first two things to check for. Either an inoperative blend door in the vent system, or a restricted heater core.
I would add “thermostat,” even though you say the coolant is hot.
Another possibility is air trapped in the heater core–especially if the cooling system has been serviced improperly by someone.
