If you can fix the problem first, you can change the O2 sensor later. You may have to try changing the ignition switch first, seeing as no mechanic can do better at finding the problem. Somebody should read the codes.
| Hard to crank | 2 | 532 | June 17, 2010 | |
| Bad oxygen sensor? | 10 | 980 | June 8, 2007 | |
| 2005 Camry won’t start | 20 | 2468 | December 27, 2023 | |
| Problems with o2 sensor | 25 | 1148 | February 27, 2024 | |
| 04 3.4 Impala hard start 02 sensor question | 9 | 3083 | February 23, 2019 |
