We have a Hagglund BV206 tracked vehicle that is powered by a European Industrial Ford V6 (136 hp). The engine was manufactured pre-1984 and requires leaded fuel. We haven’t run leaded in it and now it tends to begin losing power once it’s been running fro 1/2 hour or so under load. Could this be due to running unleaded fuel in it? It is not a fuel/air supply problem. Are there any solutions such running a lead substitute additive or replacing the heads with ones designed for leaded fuel? These engines are similar to the Bronco II, or so I’ve heard.
Related topics
| 7.3 L Diesel | 2 | 634 | August 3, 2009 | |
| 2016 Ford Expedition EL - Power loss at a bad time | 2 | 862 | January 20, 2021 | |
| Is the Ford V6, 4.2 Engine a dog? | 19 | 140476 | September 19, 2018 | |
| 1995 ford contour v6 losing power | 2 | 850 | August 15, 2009 | |
| 2006 Ford F350 6.0 Diesel | 3 | 3175 | May 12, 2008 |
