Jad2007, there are a lot worse issues out there than the converter on your car, or the lack of one. You are not going to have someone from the Feds coming after you if you can the converter. A shop won’t do it, but you can.
Cars of this era, both domestics and Asian, were bogged down with computer controlled carburetors, air injection, miles of vacuum hose, thermovalves by the case, etc. and often there were so many problems due to this stuff, and coupled with the de-tuned state of the cars anyway, a converter problem is a minor issue.
If you wanted to spend some time doing it you could remove most of those vacuum valves, hoses, air injection, computer controlled carb, etc. The carb could be replaced with an earlier non-CCC version, the ignition timing bumped up a few degrees, and both performance and mileage would probably improve. To go even further, a camshaft change would make a very noticeable difference. If you ever did this I would advise keeping the EGR circuit intact; that pays big benefits.
Give you an example here. Some years back I had a Subaru 4WD wagon that was outfitted with the always trouble-prone Hitachi carburetor. These carbs were near junk new and went downhill from there.
This car, just like all the others, got 27 MPG on the highway. I made an adapter plate and installed a one barrel carb from a 200 cubic inch Ford 6. One would think that would be too much carb for the Subaru motor and I expected to have to do some tweaking.
Not. That car would fire right up hot or cold, idle smooth, and most amazing of all - it got 38 MPG. The first time I checked the mileage I just knew that I had somehow made a mistake. Follow up checks showed it to be true - 38 MPG.
Kind of baffling, huh?
So did I screw up the environment here by eliminating the original carb and some of the garbage on top? I would like to think not since the vehicle would go 10-11 miles further on a gallon of gas than it did with the factory carb.
I also had an old carbed 70s era Monte Carlo and after a few months of some modification and wrestling I had that car (350/4 barrel) getting 21 MPG on the road with the A/C running. Not too shabby, if not environmentally conscious.
Civil discourse from Jeremy? After the horse comment and especially the “laying off the crack” comment? Jeez.
