Hi all,
Long story short I brought my 2013 Subaru Crosstrek into the dealer for a standard 30k maintenance and since getting it back I’ve had a significant drop in MPG’s. From 27-29 down to 21-23. They are trying to tell me its just because it’s winter, but I’ve had the car for two years - same work, apartment and parking situation, and never had this bad mileage. I bought the car in January 2013, and we had the worst Minnesota winter during 2013-2014 and I still managed 27-28ish mpg then. I think its something they did during the service but they can’t replicate the problem on their end.
Long story long:
30k maintenance included:
Replace filter with Genuine Subaru oil filter
Check and top off all fluids
Rotate tires and set tire pressures
Replace cabin air filter
Replace Spark Plugs (if applicable)
Replace Air Filter
Inspect Brake Pads and entire Braking system
Replace Brake Fluid
Check Axle Boots and Shafts (front & rear)
Check operation of clutch system (if applicable)
Inspect Steering and Suspension systems
Inspect Cooling system/Replace Engine Coolant as needed
Inspect Camshaft Drive Belt (if applicable)
Inspect Wiper Blade condition
Inspect Fuel lines and system operation
Inspect and Top Off Differential (front & rear)
Inspect and Top Off Transmission Fluid
Complete Multi-point inspection
Free car wash
They additionally replaced my engine air filter which they said was dirty (hadn’t been replaced in 2 years)
Here’s all my observations:
Ever since I got the car back, January 2nd, 2015, my MPG on the digital readout went form hovering between 27-29 down to 21-23, sometimes 18 and the highest is the upper 24’s. I brought it back into have them check it 3 times now. I live in Minnesota, every time they tell me, “it’s the cold weather, you cant expect better milage in cold weather”
1st time (Early February 2015): They diagnosed a sound in the transmission and replaced the entire transmission.
2nd time (End February 2015): They did a fuel consumption test and somehow managed 33mpgs as opposed to my consistent 21mpg. I think it may have to do with them starting it from a warm garage rather than cold starts (real world conditions I’ve had for two years)
3rd time (Today, March 1st): I noticed fuel gauge didn’t fill to full when I got it back, and intermittently will show a notch or even a quarter tank missing even though I know the tank is full. They couldn’t replicate that problem either today (intermittent) and are now refusing to diagnose my car further.
I’ve had the car two years now and never had mileage this low. I bought it in January 2013, and last year we had the coldest weather in a long time and I was still getting in around 28mpg. This can’t be the issue.
I asked them to check the MAF sensor, the air filter, and now the sending unit, and I have no idea whether they did any of that. I’m assuming not because check-engine light wasn’t on and they don’t want to be told what to check. The only reason I can find that they got 33mpgs during their fuel consumption test is that they start the car warm from a heated garage, and then parked in a garage over night - I never had heated parking in two years in Minnesota so there’s something new that is going wrong since the 30k maintenance that is affected by cold vs warm start.
Any thoughts at all as to how to proceed? They don’t want to do further trouble shooting and are assuming it’s my driving habits or the cold weather. I want to take it to a competing dealer for a 2nd opinion so that it’s still under warranty for any repairs. Where should I tell them to start looking??
