Yeah the brake wear indicator. The theory is when the pads wear down enough that little clip causes a high pitched squeal when you put the brakes on so you know the pads are worn. To be truthful, I’ve never been able to hear the dang things so it wouldn’t matter to me. Just have to remember to check the pads once in a while like when you rotate tires.
bing
11
| Advice for front end brake pads | 19 | 312 | August 2, 2024 | |
| Electronic brake pad wear indicator? | 32 | 2793 | December 28, 2023 | |
| What does this wear mean? | 19 | 3175 | March 12, 2016 | |
| Break pad replacement time | 5 | 806 | January 12, 2008 | |
| Worn out brakes without warning? | 2 | 111 | September 27, 2026 |
