Like the cap bit broke off the stem. I used the old head because I wasn’t sure if the new one would be damaged and the original motor still had a good head out side of 2 ever so slightly bent exhaust valves that I replaced. You couldn’t even fit a fingernail under the valve it was such a slight bend.
Related topics
| Broken Timing Chain on 2007 Ford Focus | 27 | 9234 | December 21, 2018 | |
| Should this have happened? | 52 | 523 | December 14, 2024 | |
| Timing Belt Broke two days after tune-up, Engine blown | 34 | 9392 | February 14, 2012 | |
| Does front cover have to come off to adjust timing? | 24 | 12174 | December 22, 2021 | |
| Is there a defect in the Ford Fusion engine? | 34 | 46925 | July 15, 2020 |
