Experienced mechanics: Why don't they make these anymore?
Stumbled across this NAPA parts Youtube video (link below), posted 15 years ago, instructing on how to use inexpensive hub correction plates to “true” brake rotors that are slightly off kilter. Seems like a decent idea. Trouble is, these correction plates are nowhere to be found or bought now. I’m curious, anyone know what happened to them, why they disappeared? Here’s link to the relevant part of the video: https://www.youtube.com/watch?v=I5Mj_G5LIz8&t=195s
They were called “Braje Align” runout shims. I remember using them on a 97 Chevy K1500. Those were terrible about warping the brake rotors.
That vehicle cemented my love for reliable and strong drum brakes.
The runout correction shims certainly helped me years ago. Of course I do prefer drum brakes, you don’t have near the issues the finicky disc brakes tend to have.
Then why did I have to frequently readjust customers’ drum brakes, and NEVER their discs?
Well to back away from the disc vs drum debate as wonderful as it is to read about over and over again, I will try to answer the OP’s question…
It really comes down to economics… Years ago, rotors had more material to work with and were relatively expensive to replace, so taking the time to measure hub and rotor runout, index the rotor, torque it to spec, and install alignment shims made sense…
Nowadays, rotors are generally cheaper to replace and often have less material available for machining… In many cases, it’s simply more cost effective to replace a rotor under warranty than to pay a technician for the additional time required to measure runout, index the rotor, and install the appropriate shims…
On car brake lathes have also changed the equation… They can machine the rotor in relation to the hub, correcting certain runout issues without requiring the same amount of measuring and indexing… A technician can set up the lathe, let it do its work, and move on to another task in the meantime…
Ultimately, it’s a matter of labor costs, parts prices, and shop efficiency… The process of measuring, indexing, and shimming still has its place, but in today’s automotive repair environment, replacing the rotor or using an on car lathe can often be the more economical option…
A shim stack that cancels runout is sound engineering. It did not fail. Three things killed it.
He has the name right: runout shims, Braje Align was one brand. You clock the rotor, find the high spot, shim the rotor to the hub so the runout cancels. Judder fixed without a lathe.
On-car brake lathes (Pro-Cut and its copies) do the same correction with the rotor bolted to the hub it actually lives on. More accurate than a shim stack, and it takes minutes.
Then thickness. Machining a rotor needs meat to give back. Rotors got thinner for weight, and the minimum thickness stamped on most modern ones sits so close to new there is nothing left to cut. The OEM position became replace, do not true.
And price. A new rotor for a common car costs less than the labor to true one, so a shimmed rotor that comes back is a comeback the shop eats.
Your drum preference is the same story. Drums tolerate runout because the shoes float. Discs punish it, so an industry grew up around correcting them.
In the video, the hub is the faulty part and using the shim corrects the runout for the rotor mounting surface. So the discussion of rotor thickness and cost isn’t really relevant.
I can see using shims to correct for hub runout if I can identify the cause and can be sure it won’t worsen or happen again. I can’t see using shims to correct for rotor runout when correcting it by resurfacing or replacing and identifying the underlying cause can be done. If they warped once they will warp more/again unless the original cause is corrected. Just saying “these cars warp the brakes” isn’t the answer.
As to why they don’t make these anymore…there wasn’t enough market for them. Most experienced mechanics address and correct the system correctly.
And I’d add that today, even today’s cheap rotors ($10 - $15) are much better and cheaper than the rotors from 1997 (30 years ago).
Since then Low Cost Quality production has moved from Japan to Thailand, Mexico and China which is where your current Nikon camera or Mazda SUV is now constructed, with modern technology at low, low prices.
However, if you still long for the “Good Old Days” of drum brakes, India may be your best source of Old Tech and ■■■■■■ replacement parts. But BTW, the Indian vehicle industry seems to be waking up so you’d better get those shims quickly :wink:
Fwiw . . .
I’ve had several very bad experiences with cheapo brakes
Noise, don’t fit correctly, etc
I came across a TSB for challengers and chargers with 6-piston Brembo brakes like I have, that use a similar part but for a different problem. I’m just mentioning it because it looks like the same part.
Front Click Noise at Low-Speed Turn. They called it a friction disk that went on the hub in between the hub and rotor.
Map Title 05-001-22
Every time I found a bent wheel hub, I replaced the hub. Adding a shim can result in a come-back if the shim is lost or repositioned during a brake service.
I think there must have been a lot of returns/exchanges and waste from people trying to correct rotor thickness variation (brake pulsation) using hub shims.
Adding a shim to compensate for a warped rotor will affect the wheel mounting surface and cause wheel run-out; vibration.
The brake comments got a lot of “likes”, but misuse of a product will get bad results.
Brake rotors were thin in the 1980’s.
During the last 20 years, I have machined thousands of brake rotors. I find that most rotors can be resurfaced twice, and I measure before and after using a micrometer. Vehicle manufactures require technicians to resurface brake rotors rather than replace, when performing warranty repairs.
An example of brake rotor prices at AutoZone for a Honda Civic:
Call me ‘dense’, but how and where do you place a pad thickness gauge as illustrated:
to measure brake pad thickness?
Thanks, Faye’s channel is terrific!
I always thought thoug, that if a wider piece of gauge fit between the pad and the rotor, that there was less pad left.
You don’t place it between the pad and rotor, you put it next to the pad to judge its remaining thickness.
On both my Chevy and my Harley the pads have a groove in them. As the pads wear the groove shrinks. When the groove just about disappears it’s time for new pads.
Fair pushback, and one sentence of mine was too broad: “nothing left to cut” is true of some late-model specs, not most. Plenty of rotors still hold two cuts if you measure before and after, and 0.2mm under new is not 0.2mm over minimum. I’ll take that correction.
What I’ll keep is the economics. At $10-15 a rotor, truing pays the bay less than a swap, so most shops replace even where the spec permits a cut. That is a commercial call, not an engineering one, and it’s why the shim-and-lathe trade died quietly.
Your comeback point stands too, and I underweighted it. A shim is a part that can move at the next pad slap, and no spec covers that. When the hub is the source, a new hub is the honest fix.
Just for giggles I selected brake rotor prices at Rock Auto for a 2023 Honda Civic, 2 liter, I4 …
Economy - 2 under $10
Daily Driver - 8 under $15
Fully Coated - 4 under $15
But if your daily school dropoffs for the kids requires Daytona Speedway, Extreme high speed performance and braking, the top of the line is available for $65 :rofl:
I’ve had extremely bad experience with autozone brakes
don’t fit properly
make noise
spend more and get better results, imo
“You get what you pay for”
I don’t know if that expression is in the B i b l e, but it should be!
Wisest piece of advice out there.
