Engine misfire
I think your spider lines are leaking raw fuel inside the intake. Verify spark, then pull the air butterfly and check for fuel leakage in the plastic spider lines .
are there any engine codes even if there are no ck engine lights on go yo auto zone and see if they can read anything i had a 2004 impala with the same symptoms it was a o2 sensor
