EllyEllis wrote:
A 4 heats up faster, thus incurring less wear.
While this may be true in theory, in practice, it’s affect on overall engine wear is likely insignificant.
an engine that turns more RPMs will have more cylinder wear,
but it doesn’t make any difference.
Is that really what was said? I think we can say that a simple count for the number of times a piston goes up and down isn’t the primary factor for cylinder wear.
4 valve engines operate at higher RPMs, forcing them to
run slower would hasten wear and waste fuel.
This isn’t universally true. There are many low-rpm (long stroke) engines out there that have long engine life and are fuel efficient. Other factors are involved.
Higher engine speed helps more than it hurts.
I don’t know where you got this. Higher engine speeds do wear engines faster than lower engine speeds. But that really tends to be a factor with the RPMs that racing cars run at and not typically the RPMs that passenger cars run at.
One person, I’ll not mention his name, said that by shortening
the duration between sparks they had solved the problem with
4 cylinder engines.
This makes no sense to me.
The inbalance of a V6 will cause uneven wear and tear.
Engine designers long ago figured out how to deal with the V6 engine angle quirks. There are no generic V6 engine wear and tear problems.
An I4 is ideally balanced.
This too is oversimplified and often not true. Look how many I4 engines have a dedicated balance shaft.
