I drive a 1995 3.1L V6 Pontiac Grand Am SE.
My mechanic told me that my EGR valve was throwing a code, so I took it off and cleaned it out and tried to fish out some of the carbon in the air intake tube. I used carb cleaner on the valve and the tube and I sprayed a little bit of air duster into the tube, but it made a funny noise so I stopped after about 1 second of spraying.
When I put it back on, I forgot to snap the wiring harness back onto the top EGR solenoid. I reconnected the negative battery cable and started my car. The gauges red fine. I revved my engine a few times and everything seemed okay. Then I turned off my engine and then turned it back on to listen for any rough idling (that’s why I decided to clean the EGR in the first place). Then I turned it off.
When I got out of the car, I realized I forgot to reattach the wiring harness to the EGR. I disconnected the negative battery cable and it sparked a tiny bit. I reconnected the wiring harness to the EGR. Afterwards, I noticed that it had leaked some fluid (I’m guess oil?) into my engine. There was a very small amount of light smoke or steam (not sure which), but it stopped a minute or two later. I’ve attached a picture for reference.
Is it safe to reconnect my negative battery cable and try restarting my car???
