Does timing belt jump cause engine damage?
I reviewed the posting in this forum. I am new to this forum. I like to have your insights on this issue.
My TOYOTA Camry 1999 (Less than 90K miles) was driving OK. I do check under the hood on and off, I did not do that check for awhile. Last week my car started OK. Within two(2) minute driving RPM started decreasing and lost power. The car engine cut-off. It crank the engine as I turned ignition, but it did not start. I towed the car home. I towed the car to auto service shop. I trusted this mechanic. He did some critical work for me on other cars in the past. Other mechanics make me run around on situation and suggested motor replacement on my previous cars. This mechanic addressed the issue and put my car on the road without changing the engine.
My mechanic is telling that my timing belt was jumped and hit water pump. He did leak test and find leakage in middle 2 cylinders. He wanted to replace the motor.
He performed the leak down test using Cylinder Leak-Down Tester as shown in http://www.harborfreight.com/cylinde...ter-94190.html.
He removed upper timing cover, front passenger wheel and rotated the camshaft manually to do leak down test .
The mechanic performed the lead down test in my presence. Here are the readings from leakage Gauge.
Outer two Cylinders 0 - 10 % (Close to Green)
Inner two Cylinders 100 - 80 % (Red)
As he proposed for engine replacement in situation, because he said the inner two cylinders have bent valves. I am in dilemma to see him as scam artist.
I did not drive on high speed and drove 2 minutes from starting. My car has non-interference engine, so it had timing belt instead of timing chain. I am not sure bent valves story adds up with non-interference engine.
Does this situation cause such engine damage?
Do we able to do leak down test properly with camshaft timing being out?
I learned that when the timing belt breaks, the camshaft will always have the valves open on one or two cylinders. A competent mechanic can identify this before even opening the hood by the sound of the engine cranking. This will show up on a leak-down test as valve damage, when the valves are simply being held open by the cam because they’re out of sync with the pistons.
Did you face such situation? How did you resolve it?
Is the leak down test right diagnostic on this situation?
Thanks for your insights.
