Just talking about high-rel maintenance on the aircraft engine pre-heating thread, I realized I had not updated this posting. Even when advice is useless, I really appreciate a fellow human taking time to respond to my request for information. No one is obliged to do it. Thanks to all.
There was some good information there. I had to choose which advice was important to my circumstances, which is an attempt to replace with a plan, parts that do fail at times, but without warning. I chose to take the advice that the sensors eventually fail, and decided to have the new ones put on. With nearly 150,000 miles I do not think they will need to be replaced again.
It was a good thing I had them replaced instead of just buying the parts and taking them with me The hardware on the rear sensor was shot and they had to order new, which would have been a wait of many days in Mexico.
I think it was Docnick who best understood high rel maintenance, with his tale of replacing parts on vehicles used in the desert every two years. Someone else wondered why I didn’t just start replacing parts en masse, even things like the head gaskets, which is sort of ridiculous on a car which does not have a significant failure rate on head gaskets. The idea is to find out which parts fail and when. Then, with a reasonable plan, replace parts which are:
Most likely to fail in the near future, even if you are not sure exactly when, and if no other formula exists, when the car has reached its 50% point, if it is likely to fail at all. I do not expect to drive this car more than 300,000 miles, so now is the time.
Likely to either disable the car, or cause damage if it is driven. I found plenty of mechanics who said driving with bad sensors can wipe out the catalytic converter. Some posters seemed to think I could drive that car hundreds of miles with bad sensors.
If I had any reason to believe there is a significant failure rate on Toyota head gaskets, yes, I would have the suckers replaced per plan. But, I have no such information.
If I had any reason to think the transmission would fail in the near future, I’d have it rebuilt as well. I know it can happen, but I believe it is rare when the ATF is changed often. So, on that, I am not having it rebuilt.
By the way, perhaps there is only one heated sensor, the one behind the cat converter as someone said but my first sensor failed some time ago, and the failure was THE HEATER BURNED OUT. CEL came on, and that was the code stored. It was the a/f sensor I forget which bank.
I also replace my batteries at 5 years, no matter how good it might be. This is also about the halfway point on a car. I used to wait until they broke, miss work and have to work on that car at 20 below zero after paying top dollar for a battery. This was the first thing I learned to replace with a plan.
I also have a new policy to replace all external light bulbs every 75,000 miles. When this Sienna had about that many miles, I asked about that, since cops are using bad bulbs as an excuse to harass people into letting them search their cars, like common criminals. I got some really bad advice here, including positive statements that bulbs don’t fail any more. So, I decided not to bother. At 85,000 miles the high-stop light went, I caught it before the cops did, so I learned to replace all bulbs on a schedule. A California attorney posted on the Sienna Club that in California the cops are now writing MOVING VIOLATIONS for bad bulbs. It is time to shift gears on the old traditional wait till it breaks concept.
I used to do it the way many of you seem to recommend. Wait until it breaks. If there is an Autozone just down the street, as is the case for many of you, this may be a valid choice. Just as Docnick’s desert vehicles could not afford to do this, neither can someone living far from parts/service. This concept is so simple I am stunned that there are so many people who can’t grasp it. Thanks, Docnick, good job!
If one does this sort of thing for a while, you learn you can drive a car a long ways with fewer failures, and in the end the cost of high-rel maintenance is small compared to what most people do which is let this stuff go, then throw up their hands and get a new car, which would cover a lot of parts and repairs.
I understand eventually I am going to miss something. Maybe my head gasket will fail, heh, heh. Such is life. All we can do is our best.
