I have an '02 Chevy Cavalier whose passenger side headlight went dim suddenly one day when I started the car. When I start the car, the daytime running headlights indicator flashes and clicks, and then the service light comes on. I have tried the following:
- Swapped lightbulbs between the two lights. It is not the bulb.
- Swapped fuses between the two lights. It is not the fuse.
Even stranger, when I remove the fuse to the dim headlight, the light stays on. My guess is that I have a short somewhere in the wiring. I took a brief look at the connection between the socket and the wiring and everything looks good there. Has anyone else experienced this problem? Where should I look for this short, or is the problem somewhere else?
Thank you kindly,
Ray
