I have a 2020 Kia Rio with a CVT. From what I’ve read, they have better reputations for durability than the awful mid 2010’s Nissans, but still fall short of the IVT designs Kia implemented in the following years. I’m getting close to 80K and never have had the tranny serviced since it’s not officially recommended. I basically never do hard accelerations from a stop, which I know is bad for them, and am yet to have any issues. My plan was to just sell it before the 100K warranty and let the new owner decide about when/if to drain the fluid. BUT I now might instead be selling it to a younger cousin around that 100K mark, so if it really needs this maintenance, I want to make sure to do it. Is 80K too late, could it cause an issue the way some long-delayed tranny flushes can? Or am I still likely in the safe zone? Thanks. =MM=
You’d be doing them a good favor by having the fluid changed. It must be with fluid meeting the exact factory spec. The easiest (not necessarily the cheapest) way to do that is have the dealer change the fluid. But know what fluid is needed and confirm with them that they’ll be using that fluid.
It is recommended to replace the transmission fluid every 60,000 mile if operated under severe usage conditions.
It would also be safe to replace the fluid if driven under mild driving conditions.
I honestly totally had forgot about asking about it a year-and-a-half ago. I was kinda stunned that a guy at a shop had actually recommended not doing a maintenance step. So I guess the consensus of the Car Talk Community is “Don’t worry about it being too late if it’s past due. A flush only causes damage when the tranny is already giving problems.”
Replacing the fluid won’t cause harm to the transmission.
Transmissions may need a pan resealed, axle seals replaced or oil cooler/lines replaced during the life of the vehicle. Old fluid is removed, new fluid filled into the transmission. I have never seen a transmission failure occur after any of these repairs.
A fluid exchange (flush) is simply an automated method of replacing the fluid. The machine does not inject fluid into sensitive parts of the transmission, the new fluid enters the sump through the oil cooler lines just as it does while driving the vehicle.
Changing your fluid cannot cause any damage by itself, if everything is fine inside the transmission/transaxle…
Generally speaking, you are NOT supposed to flush a CVT transmission using a normal pressurized flush machine, only drain and fill, or pan drop if it has a pan and filter if applicable, or the dealer/shop might have a CVT ATF specific exchange machine that is designed to exchange the ATF in CVT transaxles…
Two different services get lumped together here, and the difference is your whole question.
A “flush” forces fluid or solvent through the unit under pressure to displace the old. That practice earned its bad name on worn conventional automatics, where loosened debris finished off clutches that were already on the way out. What the manufacturer calls for on a CVT is a drain and fill: 3 to 4 quarts out, the same back in, road test. Nothing gets pushed through anything. At 80K with no symptoms, that is not the gamble you are worried about.
The real gamble is the fluid. The ticket has to name the CVT fluid the owner’s manual specifies, not a universal CVT fluid and nothing with Dexron on the label. Ask them to write the part number on the estimate before they start. Wrong fluid is what actually kills these, and it takes a while to show.
Two more things for your cousin’s sake:
Set the level at the specified temperature. These are picky about level, and an overfill is worse than a quart low.
Do it now at 80K, then again around 110-120K, and keep both receipts in the glovebox. A buyer who sees two CVT services does not sit around wondering about the CVT.
You can check the fluid before you book anything. Most of these have a level plug rather than a dipstick, but if what comes out on a white rag is dark or smells burnt, the drain and fill moves to the top of the list and happens before the sale, not after.
Find myself in agreement with davesmopar again. My CVT experience is on Subaru, not Kia, but best advice there is to drain and refill, not flush. Also agree with those who recommend using the OEM fluid and to follow the prescribed drain-fill procedure that could include levelling the car and bringing the CVT fluid to a prescribed temp. CVTs appear to be a little more picky than geared systems.
A little off topic. I asked an independent shop about changing the fluid in my 10 speed, automatic transmission, their reply: “no, wait until it fails, then replace the transmission “! Me, had the transmission service at the dealership.
