how do you bleed the coolant sytem on a 2003 infiniti g35 with a3.5L engine
Get the engine up to operating temperature. With the engine idling slightly loosen the upper radiator hose clamp. Take a flat bladed screwdriver and slip it between the upper radiator hose and the hose neck on the radiator. Allow the engine to idle until all the air is purged out of the cooling system. Retighten the hose clamp.
