I replaced the front control arm bushings on my always-in-Florida Mustang. There were only two on each arm. I replaced them with polyurethane bushings. I could have bought control arms with the poly bushings installed with new ball joints but I had special, longer ball joints I wanted to keep.
I have a 12 ton press in my shop. Oxy-Acetylene torches, a small lathe, impact chisel and BIG hammers. I have 40 years of wrenching on rusty cars from Ohio. I have the scars and tetanus shot records to prove it.
The bushings laughed at my 12 ton press. They scoffed at my impact chisel. I darn near threw the lot in the trash to order poly bushed control arms and another set of the special ball joints as significant expense. I successfully changed those bushings but it was a massive pain to remove the factory bushings from the control arms. Don’t be surprised if a mechanic refuses to replace the bushings in your factory arms. They may have learned what I learned! I got the job done but I’d NEVER do it again!
Consider the OE parts lasted 215K miles… And the new ones likely include new ball joints as well. Don’t they need replacing too? Do you really think this thing has another 215K in it?? If the aftermarket replacements last 100K miles, I think that’s when the car becomes scrap metal, don’t you?
