Before assuming a worn out clutch, how can you check the clutch master cylinder and release mechanism?
As a general rule a hydraulic component failure will make it difficult or impossible to get the vehicle into gear. A worn out clutch is detected by slippage. What are your vehicles symptoms?
~Michael
