My wife and I purchased our 2005 Chrysler 300 Limited in May 2004.
Our 300 has over 117,00 miles as of May 2011. It has been a rather dependable automobile.
I have enjoyed it almost as much as my HD. We have performed maintenance as close to the schedule as possible.
I failed to drive the car as often as our second car is an used 2002 S430 which had been my primary auto until about two months. My niece and nephew reported to my wife that the car was not “doing something right”. No one could really explain, so I had drove the vehicle myself to determine the issue. The transmission had the feel that it was being “slammed” into the next gear without any clutch. Once the car was warmed up, it appeared that when it shifted at 38-40 mph or 48-50 mph, the car shudders. It almost resembles the feeling you get when you run a car across those strips in the road.
I took the car to the dealership where I have had it serviced locally. They replaced a module which had Technical Service Bulletin from Chrysler for noted similar problems. The first module replaced did not resolve the problem. I took it back and they tried again with the end result being same as before I took the 300 into the shop, transmission appeared to shudder when shifting at the midrange gears.
The dealership as another option recommended that the transmission be replaced. I was not confident with their assessment as I had the distinct feeling they were not clear on the real issue.
I took the car to another service shop which I had more confidence in their work. I asked that they check the car for the problem with the transmission as I wanted their assessment. At this point, I had pretty much decided that I would get rid of the car, but did not want to give anybody else the troubled vehicle nor did I want to have to rush to decide on an automobile to purchase.
The second shop recommended the transmission be replaced, as well several other items be checked as there appeared to be oil leaks. The CAM plugs had been replaced as part of the service the dealer performed though the engine area had not been cleaned of the previous oil. That news was alarming, as the price estimate for a replacement engine was around 6500-7000 smackeroos, way outside of my comfort for repair on the car.
I was able to locate a used transmission with only 86k on it through a very gratuitous turn of fate. I digress, however, as the source for the used transmission was available only to licensed shops.
Two shops had referenced a transmission repair shop as one of the best in our small county. I left the car with the transmission shop for their testing, and it came back with their recommendation that the problem existed in either the coil or spark or an area related there.
I again took the car to the second shop and asked that they check the engine thoroughly for any issues with the spark plugs, wires or similarly related issues. The shop reported that the motor compression was at 190 across all six cylinder and the spark plugs and wires were new and there were no issues with the coils.
I am most happy that the engine is in excellent condition. I have planned to take the car back to the tranny shop as I reported the findings to him of the other shop. I am concerned about the transmission, though I am driving it about 60 miles round trip to work about 2-3 days each week. It still convulses at the mid-range shifting but otherwise runs pretty good after that. The car body is in very good shape as is the interior.
I was reluctant to trade or sell the car with the problem noted as I hate to leave someone with the problem. Have you ever encountered anything similar on the Chrysler’s you’ve experienced? What resolved the issue? I can imagine getting a new car in a few months. I just hate having to run out and spend money on cars until I really have one that catches my full attention and desire.
Thanks
Ronald
Salinas, California
