Chevrolet Tahoe iwth 250K miles, started shaking a little, P0300 code
What year is it?
Google is your friend:
Possible causes
•Faulty spark plug (s)
•Faulty ignition coil (s)
•Clogged or faulty fuel injector (s)
•Intake air leak
•Fuel injectors harness is open or shorted
•Fuel Injectors circuit poor electrical connection
•Ignition coils harness is open or shorted
•Ignition coils circuit poor electrical connection
•Insufficient cylinders compression
•Incorrect fuel pressure
Tech notes
The P0300 code means that a cylinder(s) is misfiring or is randomly misfiring. Start by checking for intake leaks, intake gaskets are a common caused of multi-cylinder misfiring. If no leak is found the next step is to replace the spark plugs. If the problem persists more tests needs to be done to diagnose the problem, see “Possible Causes”.
There are factory service bulletins for the following Chevrolet models:
2000 Chevrolet S-10
2000-2008 Chevrolet Camaro
2000-2008 Chevrolet Lumina
2000-2008 Chevrolet Cavalier
2000-2003 Chevrolet Impala
2000-2003 Chevrolet Malibu
2000-2003 Chevrolet Monte Carlo
2000-2003 Chevrolet Silverado
2000-2003 Chevrolet Suburban
2000-2003 Chevrolet Tahoe
2000-2003 Chevrolet Venture
2001-2008 Chevrolet Express
2002-2008 Chevrolet Astro
2000-2003 Chevrolet Avalanche
2000-2003 Chevrolet Trailblazer
2003-2008 Chevrolet Blazer
2003-2008 Chevrolet S-10
2003-2008 Chevrolet Trailblazer EXT
2000-2008 Chevrolet Factory Service Bulletin OBDII Code P0300
2014 Chevrolet Silverado 1500
2014-2016 Chevrolet Corvette
2015-2016 Chevrolet Silverado, Suburban, Tahoe
2016 Chevrolet Camaro
