"Check Engine" Light
Engine runs perfectly but “check engine” light" stays on due to faulty Emission Evap control pressure sensor(P/N; 89460-0w020).
Problem is Toyota no longer makes this part and there is no after market for it.
Also in Calif. vehicle won’t pass smog test and thus can’t be registered.
It appears I may have to “junk” a perfectly good truck.
Any suggestions would be greatly appreciated.
It would appear that RockAuto has this part. http://www.rockauto.com/catalog/moreinfo.php?pk=817880&cc=1278828
Great Catch! Good job, tester!
Or, junkyard. I mean “automobile recycling center”.
Tried Rockauto , but they didn’t have part.
Any other suggestions ?
Can they order it for you?
What code exactly are you getting?
www.summitracing.com shows it for $151.95
summitracing.com/parts/SMP-AS214/
Try a Google search for ‘AS214’ if that also fails.
Call the Bureau of Auto Replairs. They may grant you a waiver since the part isn’t available as an OEM replacement.
Sell it on ebay to someone in a state that doesn’t have emissions testing.
