I have 99 Merc. Grnd. Marq., code 0174 know showing up on the scanner, I also had 0171. I have done a vacum test and holding 21.5 Hg, I have change all rubber vacum hoses even if they did not need changed. I even changed the gromet for the PVC Vale on the right valve cover. Checked the injectors and all are clicking. I had changed spark plugs earlier and show a normal firing color. I had changed the fuel filter(last week) and MAF sensor a month ago. do I need to change the MAF sensor again. Lost?
Related topics
| Check Engine Light On | 13 | 1039 | February 2, 2009 | |
| Check Engine Light - ON | 11 | 902 | January 15, 2009 | |
| Check engine nlight on | 4 | 592 | January 25, 2009 | |
| Check Engine light... AGAIN! (Mazda6s) | 7 | 2641 | June 9, 2013 | |
| 0171 @ 0174 | 4 | 566 | August 1, 2011 |
