[quote=“db4690, post:18, topic:99785, full:true”]
A word of caution . . .
If you’re contemplating doing your own battery replacements again, you might want to consider a memory saver
Not only will it preserve your radio and clock settings, it will also preserve your readiness monitors . . . an important detail, if the car will be due for smog inspection soon. It would suck to show up at the smog inspection place, only to get turned away, because the car’s not ready. That’s time wasted, in which you could be be doing better things
[/quote]In relatively new cars, I thought these were stored in nonvolatile memory so disconnecting the battery wouldn’t erase them. This is also why disconnecting the battery won’t clear error codes.
Removing the battery WILL clear your readiness monitors, no doubt about it
As for the radio and clock settings, it depends on the car, but most cars will need the clock reprogrammed. Some cars don’t require a radio code, but that could be a lengthy discussion, as to the reasons why
As far as “relatively new cars” . . . what is your definition of relatively new?
[quote=“db4690, post:22, topic:99785, full:true”]
That is incorrect
[/quote]A decade or so old.
To clarify my earlier reply, I was only referring to readiness monitors. My thinking was hat since error codes can’t be erased by disconnecting the battery, readiness monitors should also be unaffected. But I stand (sit?) corrected.
Sure we hired a new mechanic, and my old bud is like gees got to teach them everything. 10 year old knowledge ,is now obsolete. So me a computer guy working with the mechanic guy, to get analysis programs and even just proprietary manuals to work. We are both old school guys making our way bravely into the whole new worlds
