I found where the sound comes from, its from the engine but why? The only time i touched the engine is when i was cleaning it, with some metal brush, does that affect it? Like a sound comes inside the engine.
Sound ? Turn on problem ? Going to need a little more to go on here.
Like a cranking sound
Well everytime i turn on the car, it cranks and struggles to turn on
video posted on youtube would help?
Sorry, it sounds like something is hitting inside the engine
“cranking” is that rr rr rrr sound with the key in “start”. “starting” is when it pops, catches, and runs on its own. Which of those is your problem?
Like 2 metal things inside the engine.
It cranks and at the same time it sounds like metals hitting inside the engine and it takes a while to start, or sometimes it doesnt so i try again.
I havent found a solution
After it starts, does it run OK?
It does, maybe its the started but i changed that like less than 2 months ago
It does but maybe its the starter, but i barely changed that like less than 2 months ago
First of all we need to know what year Sentra we are talking about.
Then we need to know what part of the engine you were cleaning with a wire brush.
If you changed the starter…did you make sure to install any shims that were on the old starter.
There should be a "Cranking sound as you start the engine, so you need to explain a little better what odd sound you are hearing. An audio clip would be great!!!
Yosemite
I’d pull the starter and inspect the gear on it and the entire ring gear on the flywheel for wear.
What sound will it sound if the spark plug would be broken?
Your symptoms are consistent with a starter motor or flywheel problem.
Next time your car is at the shop ask your mechanic to disable one cylinder by disconnecting the spark plug. Then you’ll know how your car would sound if one spark plug wasn’t working. When I’ve had that happen there’s not much indication sound or otherwise during cranking. But it shows up in spades during idling. Instead of the normal steady running humming sound, you hear that along with a very noticeable chug … chug … chug sound. If you dangle a paper dollar bill over the exhaust pipe exit point, with the engine running properly it will be blown to an angle and more or less stay there. If a spark plug wasn’t working, the dollar bill will move wildly back and forth. There isn’t much of a metal on metal sound if the spark plug isn’t working. If it broke off and part of it fell into the cylinder, then that could happen, but that’s a pretty rare problem.
