Car starts and runs as long as I hold the key then dies
Hello,
I have a 2010 Toyota Camry and when I turn the key to start it starts and will run as long as I hold the key in the start position. As soon as I let go of the key the car dies.
Any suggestions on what I can do to fix it. Thinking I might need to replace the ignition switch but not sure.
Any help is appreciated, thanks.
I’d agree that’s it’s probably the ignition switch.
Pretty good chance it’s the ignition switch. Alternate idea, some ignition systems use different circuitry for producing the higher- voltage cranking spark vs the reduce-voltage running spark. Engines usually start better using higher voltage sparks. So it may be the reduced-voltage spark generation circuity.
Not a new invention. My 50 year Ford old truck uses slightly different circuitry for cranking vs running, and could exhibit this same symptom…
What George is talking about is either a ballast wire/resistor or ignition control module, which your car has neither.
It is sounding more and more like the problem is a faulty ignition switch. OP might want to ask their shop if they have a simple, inexpensive test they could do to verify that’s the problem before actually replacing the switch. For example it might be possible for them to plug a new switch into the wiring harness and test it without removing the existing switch. Or there may be voltage tests.
Another one for ignition switch.
I had to replace the ignition switch three times in the 8 years and 100,000 miles I owned a 1965 Rambler Classic 550. The first time it happened, I was driving along and the starter motor came on.
I have never seen the advantage of combining the ignition switch with the starter switch. Chrysler corporation introduced “key turn” starting in its !949 models. I had no problem with my 1947 Pontiac and 1950 Chevrolet pickup truck that had a floor pedal to activate the starter. My 1948 Dodge had a push button on the dashboard to activate the starter. On my 1954 Buick the ignition switch had three positions: lock; on: off. To start the engine, you turned the ignition switch to “on” and stepped on the accelerator. When the engine started, the starter was deactivated. In my 65 years of driving, I have never seen the advantage of combining the starter switch with the ignition switch.
Seems like we have another 1 and done, OP has not been on in 7 days
